Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
FEBRUARY 2010 DO THE TON BIKE OF THE MONTH - WINNER! - CLICK HERE!
MARCH 2010 DO THE TON BIKE OF THE MONTH - NOMINATIONS! - CLICK HERE!
122600
Posts in
12803
Topics by
4877
Members Latest Member:
swellguy
HOME
HELP
LOGIN
REGISTER
LATEST_POSTS
LIVE_CHAT!
SHOP@DOTHETON.COM
DO THE TON Cafe Racers
Blood Sweat Tears and Grease
Big Arse Projects
Cafe Racers
my '78 CB550Kafe
« previous
next »
Pages:
1
2
3
Go Down
Print
Author
Topic: my '78 CB550Kafe (Read 3768 times)
snowman88
Hit the TON!!!
Offline
my '78 CB550Kafe
on:
Aug 05, 2008, 19:44:13 »
Well i finally got around to working on my cb550k, after having it a couple of years and only doing a few things. I don't have any pictures of it when i first got it but had a big Vetter fairing (made it kinda look like a goldwing) and it had a passenger back rest, those were the first things to come off. After that i rebuilt the carbs and cleaned the tank, both had gas left in it from the PO from 1983 (thats when the tag expired that was still on it). I think the story behind that is the carbs got clogged and the owner put in under a tarp till he could work on it, he never got around to it and then he died a couple years later. I got it from a man at my church who was some how related to the dead owners wife or the dead owner (not sure which) and i only payed $300 dollars for it and it was deliver to my door. So here's how it started out:
and here's how it looks now:
my current plan for this project is a carpy seat w/ the electrics in the hump, clip ons, a cb650 tank if i can find one, wrapped 4-into-1 headers w/ a chopped stock SV650 exhaust can (you can see it in the far left on the counter in the pics), and the rear sets moved to the passenger pegs. And i'm going to do this as cheap as possible w/out scraficing(sp) quality. I'm going to rebuild the engine, trans, and brakes myself and probably paint it myself (not real sure on the colors yet, but i'm thinking red powder coated frame/rims and a black everything else with a matching red strip)
Last Edit: Mar 09, 2009, 19:05:23 by snowman88
Logged
Buy my parts:
http://dotheton.com/index.php?topic=7354.msg65967#new
'78 Honda CB550K - project -
http://dotheton.com/index.php?topic=5136.0
snowman88
Hit the TON!!!
Offline
Re: my '78 CB550K
Reply #1 on:
Aug 06, 2008, 10:18:40 »
questions, comments, and suggestions are all welcome and appreciated.
Logged
Buy my parts:
snowman88
Hit the TON!!!
Offline
Re: my '78 CB550K
Reply #2 on:
Aug 06, 2008, 17:22:14 »
So i did a little more work on the 550 today, not much just took the front fender and the original turn signal/headlight bracket off and flipped the handle bars over to get more of the look i want. While i was doing this i noticed that VIN # on the frame doesn't match the engine VIN #. Here they both are, as you can see the frame says CB550K and the motor says CB550E, is there any difference in the K/E models?
And here's how the bike looks now.
Logged
Buy my parts:
snowman88
Hit the TON!!!
Offline
Re: my '78 CB550K
Reply #3 on:
Aug 08, 2008, 10:49:24 »
nothing to exciting, just stripped her down to bare minimum so that i can start mocking things up.
Logged
Buy my parts:
Fear My Twin
Revered Caff Racer Idol
Offline
Chicks hate my bike.
Re: my '78 CB550K
Reply #4 on:
Aug 09, 2008, 14:00:31 »
Looks like a super clean starting point thats for sure, take a rag and rubbing alcohol to that tank and see what kind of shit it takes off. Change that oil, and ultrasonic those carbs
Logged
LOUD, FAST, & UGLY. But damnit, its Vintage!
http://www.thefang.co.uk/index.htm
7/8 internal throttle $28.00
http://www.hondaminitrail.com/ct70.html
Re: my '78 CB550K
Reply #4 on:
Logged
snowman88
Hit the TON!!!
Offline
Re: my '78 CB550K
Reply #5 on:
Aug 09, 2008, 15:30:09 »
Quote from: Fear My Twin on Aug 09, 2008, 14:00:31
ya, she is a rather clean starting point. The engine is going to be rebuilt in the next few months by me and i've already rebuilt the carbs once but they do need to be cleaned again, they sat for many years with gas in them and were clogged and didn't move at all when i first got her and then they sat for close to a year after the project got put on hold again.
Logged
Buy my parts:
matt365
Offline
The Be-hatch Lives!
Re: my '78 CB550K
Reply #6 on:
Aug 09, 2008, 16:10:01 »
I'd rebuild the front caliper, get a set of clip-ons, or clubmans.
Nice set of new rubber, fork seals (they will start leaking, if the bike hasn't moved since '83) new turn signals (smaller!) electronic flasher relay, pod-filters, taller rear shocks, new springs and fork oil, check the head bearings (or just replace with tapered bearings)
You could grab a CB650 motor and drop it in?
shorter & new clutch & brake lines are a must. (30 year old brake lines... NO THANKS!)
That's what I would do for starters
It does look like a clean starting point too.
Logged
matt365
Offline
The Be-hatch Lives!
Re: my '78 CB550K
Reply #7 on:
Aug 09, 2008, 16:11:01 »
Dyna ignition & coils would be nice too, and a fresh set of plugs
Using the stock SV pipe seems a bit big to me for this application, but it's your machine, your call.
Logged
NJWanker
Offline
Re: my '78 CB550K
Reply #8 on:
Aug 11, 2008, 15:09:52 »
Quote from: matt365 on Aug 09, 2008, 16:11:01
+1 on the Dyna ignition. I put one in my 750 . Now she runs like a raped ape . Very fast .
Logged
I is what I is .
snowman88
Hit the TON!!!
Offline
Re: my '78 CB550K
Reply #9 on:
Aug 11, 2008, 16:10:09 »
Quote from: NJWanker on Aug 11, 2008, 15:09:52
+1 on the Dyna ignition. I put one in my 750 . Now she runs like a ----d ape . Very fast .
does the Dyna ignition replace the points and condensers? And where did you get yours from?
Logged
Buy my parts:
Re: my '78 CB550K
Reply #9 on:
Logged
bikerboy67
Got the patches...
Offline
Re: my '78 CB550K
Reply #10 on:
Aug 15, 2008, 19:27:19 »
Hey Snowman
Stig here....
diggin the ride....wish mine was that good
still got my bike up for grabs....waiting on the title still
may end up just parting it soon
Logged
What do you expect me to die of, old age?
snowman88
Hit the TON!!!
Offline
Re: my '78 CB550K
Reply #11 on:
Aug 15, 2008, 20:49:51 »
hey stig, you might try and post it up here in the for sale section, you might get a hit.
Logged
Buy my parts:
NJWanker
Offline
Re: my '78 CB550K
Reply #12 on:
Aug 21, 2008, 15:13:32 »
Quote from: snowman88 on Aug 11, 2008, 16:10:09
http://www.crc2onlinecatalog.com/
is a good spot for parts and such . They sell a Dyna for your 550.
Wow . I got bleeped . Since when is running like a " Raped Ape " so darn bad ? Gosh .
Logged
I is what I is .
philos1
Hit the TON!!!
Offline
Re: my '78 CB550K
Reply #13 on:
Aug 24, 2008, 09:37:34 »
HAHA, anything with the letters "R" "A" "P" "E" running consecutively gets taken out. Something to do with some spam/porn/hacker crap. Any word that has it in there gets "the treatment"
Logged
Kuyarico
Walkin LEGEND...
Offline
WWW
Re: my '78 CB550K
Reply #14 on:
Aug 24, 2008, 11:38:39 »
Check out Z1 enterprises too. Jeff is an extremely nice and knowledgeable guy. He provided me with great customer service when I bought the wrong coils. He actually noticed my error, recalled the shipment and sent out the new one all in the same day. Much better customer service than c2rconline.
http://www.z1enterprises.com/
Logged
78 CB550K
76 CB750F
www.myspace.com/whadarya
http://dotheton.com/index.php?topic=40.0
Re: my '78 CB550K
Reply #14 on:
Logged
Pages:
1
2
3
Go Up
Print
Big Arse Projects
Cafe Racers
my '78 CB550Kafe
« previous
next »
Jump to:
Please select a destination:
Turn your Brain Off and Shoot the Shit
=> DO THE TON Bike of the Month
=> Loungin at da club
===> Vintage Jackets and Helmets etc.
===> **Historical Points of Interest & Elements of Style **
===> Oscar Nominating Vids..
===> *** PRODUCT REVIEWS ***
=> Member Introductions
=> THE FIGHT CLUB
=> The Loathed & Fearsome BOBBER CHOPs and Hard-Tails!!..
=> Show 'n Shine
=> Our Cages
=> Big Arse Projects
===> Cafe Racers
===> Bob and Chop
===> Trackers
=> Tanks & Seats
=> Rear-sets & BRAKES
=> 1-800-CAFE-HELP
===> ** HOW TO's: Technical Vids **
=> Shop & Parts Manuals & Speciality Tools...
=> LEGAL & Regulatory Shit
REGIONAL info on Meet-up, Burn-outs & other events
=> Swap Meets
=> DTT Toronto Two-wheeled Gatherings
=> DTT East Coast Members
===> NEW ENGLAND DTT POSSE
=> DTT Dirty South
=> DTT Ohio Members
=> DTT Chicago Members
=> DTT NorPAC members
=> DTT Australia
=> DTT Michigan Crew
=> DTT US MID-WEST Crew
=> DTT WEST-COAST
Stuff ya Want & Stuff ya Don't and Where to Get It if you Need It
=> Selling / Buying / Swapping / Spotting
===> SELLING
===> BUYING
===> SWAPPING
===> SPOTTING
=> Buyer/Seller Feedback
=> Online or Local shops for Parts etc.
Announcements
=> SHOP@DOTHETON.COM OPEN FOR BUSINESS
=> DO THE TON Announcements
=> Major Scheduled Events
Powered by SMF 1.1.11
SMF © 2006, Simple Machines LLC
Black22
design by
Bloc
Page created in 4.422 seconds with 25 queries.
Loading...
